Date/Time: Wed, 12 Feb 2025 15:37:25 +0000
non-responsive order; pending modify
View Count: 693
[2020-11-06 15:28:50] |
User459170 - Posts: 262 |
Hi, I see a message as follows, what exactly does it mean? "Requesting order status for non-responsive order; current status: pending modify" How would we know when modify has been accepted? Thanks. |
[2020-11-06 20:08:00] |
You are using CQG. This means there was no response from CQG for some order action. Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-06 23:15:34] |
Is there some place where we can see when order was placed, when modified, etc.? Thanks.
[2020-11-07 02:48:22] |
You can check this through the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
