Date/Time: Wed, 12 Feb 2025 15:57:00 +0000
CROSS?HAIR CHART VALUES
View Count: 569
[2020-11-06 15:00:15] |
User266438 - Posts: 17 |
Hi When using Cross Hair for charts values . Is there a way to Annalise individual candles other that the current candle on the chart. IE . if i wanted to get the high low of a candle dated a week ago . Regards tony |
[2020-11-06 16:08:41] |
John - SC Support - Posts: 37891 |
Yes, you can use either the Tool Values Window or the Compact Tool Values Window. It sounds like you may have opened the Chart Values Window, which only shows the information for the current bar. Refer to the following: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
