Date/Time: Wed, 12 Feb 2025 16:19:57 +0000
Bitcoin CME Futures
View Count: 637
[2020-11-06 14:05:07] |
stabilo.boss - Posts: 2 |
Hi, Is it possible to get more than 10 depth levels for BTC on CME? I am using the Denali feed and have set max depth levels to 0 to get maximum depth by default. Thanks |
[2020-11-06 14:19:40] |
Yes we have to set this up. We will put it into effect over the weekend.
