Date/Time: Wed, 12 Feb 2025 16:04:59 +0000
CONFIRMATION FOR STARTING USAGE OF THE SERVICE BOUGHT- SC package 5
View Count: 484
[2020-11-06 13:12:25] |
Asyrys - Posts: 5 |
Dear all, Good day, Recently i have bought the SC package 5 and my question is that if everything is in good order to start using the service. For me, it is still not clear if i may start to use it or not, there is a lot of info to read on the support pages. Then, i am not sure if i already have activated as service in the platform SC. Could you check and revert to me with an info, please? Or give me some clear instructions what to do if something is not done already. I am new user of SC platform and services. Sorry if any inconvenient created. Wish you a great day! |
[2020-11-06 13:30:28] |
Yes you are all set to use Sierra Chart. You have paid for one year of usage time of the Advanced Package. The main question is if you have access to the market data that you require. What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. Here are instructions to open a chart: Getting Started, Opening Charts and Basic Trading Also update to the current version of Sierra Chart: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-06 14:47:04] |
Asyrys - Posts: 5 |
i need the services of SC package 5, that's why i bought this service....i will trade ES, CL, 6E and 6B ( mostly CME and NYMEX, maybe also CBOT). Regarding the broker, my account with AMP is in progress..(pending). Regarding the service, it means that it was automatically set for my platform and no need to set it myslef, is that right? only have to switch SIMULATION on OFF and that's it, right? Thank you!! |
[2020-11-06 20:55:57] |
The remaining step is to set Sierra Chart to work with your trading account and it depends upon what service you will be using. It would be one of these two: Sierra Chart / Trading Technologies Futures Order Routing Service (Recommended) Or: CQG Trading Platform Service And AMP needs to know that you are going to be paying for Sierra Chart directly which you currently are. So they do not need to provide you a Sierra Chart account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-06 20:56:17
