Date/Time: Wed, 12 Feb 2025 18:02:10 +0000
Sierra Chart doesnt start
View Count: 621
[2020-11-06 11:00:06]
ZeVS - Posts: 2
Hello. After installing thr last version Sierra doesnt start. I have 32 bit Windows 7. Previous version of Sierra worked.
image2020-11-06_13-58-08.png / V - Attached On 2020-11-06 10:58:32 UTC - Size: 44.03 KB - 169 views
[2020-11-06 11:11:51]
Ackin - Posts: 1865
Look:
RESOLVED: Last 32-bit Version
[2020-11-06 11:28:26]
ZeVS - Posts: 2
i looked. downloaded all 3 versions - no one doesnt work
[2020-11-07 13:19:32]
Ackin - Posts: 1865
Notice: As of version 2177 of Sierra Chart, only the 64-bit version is provided. Therefore, you need to be using a 64-bit operating system to run Sierra Chart.
In your case, only up to version 2176
Check if you really use the 32-bit version and try also Safe mode
Sierra Chart - Software Login Instructions: Using Safe Mode
Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface
[2020-11-10 21:01:40]
Follow the instructions here to install any version earlier than 2177:
Software Download: Full Control Rollback Procedure
Are you able to update your computer operating system to a 64-bit version of Windows?
We do apologize for this issue but we are trying to simplify things by just offering one software architecture, 64-bit.
Date Time Of Last Edit: 2020-11-10 21:02:08
