Date/Time: Tue, 04 Mar 2025 16:19:36 +0000
Trade and Current Quote Symbol
View Count: 1805
[2020-11-06 07:40:25] |
User101729 - Posts: 2 |
Hi, I'm using SC Order Routing service and i have problem with three combinations of symbols when i use second symbol only for trading. I've use them before with different trading service and they worked fine. 1st when i use CL as main symbol and select QM as Trade only symbol i cant see executions and working orders on the chart. 2nd when i use 6E as main symbol and select M6E as Trade only symbol.... 3rd when i use 6E as main symbol and select E7 as Trade only symbol.... Can you please check and fix this ? I'm sure this is working with other trading service. Best Regards |
[2020-11-06 13:45:13] |
This is because the price multipliers are different: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#UsingTradeSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-22 17:28:42] |
GravisHTG - Posts: 306 |
I see the explanation , Can I had one thing. I want to trade options from the Symbol charts . I just test it and it works , but is their a way to make the Quotes visible on the charts so I can see my buy price with stop loss and profit target ? Ex : amd is at 143$ and the option price im trading is at 1.42$ Thanks in advance. And Everyday , I love even more the platform as There is nothing I cannot do . Date Time Of Last Edit: 2021-12-22 17:29:06
[2021-12-22 19:59:59] |
Yes you can. If this option is disabled: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) You will then see the price in the Window >> Current Quote Window and the bid and ask prices will be in the Chart Header. Or you could look at doing some kind of overlay from a chart for the symbol you are trading. Refer to: Overlay - Single Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-22 20:00:30
