Date/Time: Fri, 02 Oct 2026 19:04:07 +0000
Data feed denali
View Count: 1316
[2020-11-06 02:17:46]
User334419 - Posts: 19
I would like to knows if the data feed denali needs a brokers account ? What is the price of the denali data feed for eurex and the bundle ? Moreover is denali the same performance as CQG or rithmic ?
Furthermore, is it true that rithmic does not match at the end of this year with sierra or not ?
Thanks for your response,
[2020-11-06 15:40:27]
John - SC Support - Posts: 48091
There are a few items getting mixed up within your questions. We will do our best to try and cover all of it.
First, with regards to the Denali Exchange Data Feed. This data feed only has the CME Group data. Since the CME Group requires a funded, live trading account in order to qualify for the lower-priced non-professional exchange fees, it is certainly recommended that you have a brokerage account. Otherwise, you would need to pay the Professional fees, which are much higher.
We have available the following service to be able to open a brokerage account with a minimal amount of funds that can be used to validate your non-professional status:
Easy Solution to CME Funded Trading Account Requirement
Pricing for the Denali Exchange Data Feed can be found on this page:
Second, as mentioned above, the Denali Exchange Data Feed is only for the CME Group. If you want data from EUREX, then you would need to use the Sierra Chart Exchange Data Feed and enable the EUREX exchange. For information on this data feed, including pricing, refer to the information here:
Also note that you can use both the Denali Exchange Data Feed and the Sierra Chart Exchange Data Feed at the same time. If you do, there is a $10.00 USD credit to your account each month in which you are using both. For more information, refer to the following:
https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed
Third, our opinion is that the Denali Exchange Data Feed is superior to other data feeds. We connect directly to the CME Group to obtain the data and have our connections in the same data center. In addition, we offer 1400 levels of Market Depth for the CME Group symbols.
Finally, we currently do not offer any technical support for Rithmic.
Date Time Of Last Edit: 2020-11-16 19:12:08
