Date/Time: Wed, 12 Feb 2025 16:14:43 +0000
US Equities
View Count: 513
[2020-11-06 01:07:20]
User94606 - Posts: 327
I have been using the Sierra Chart platform primarily for futures. I am currently use Denali and Interactive Brokers. How do I create a chart with us equities such as MSFT, AAPL, FB and UNH?
[2020-11-06 15:30:24]
John - SC Support - Posts: 37893
Since you are setup to trade Futures using the Sierra Chart Order Routing Service, you will need to install a separate copy of Sierra Chart to be used with Interactive Brokers. Refer to the following:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
We recommend using the Sierra Chart Exchange Data Feed for the US equities data and activate the US Equities exchange. Refer to the information here:
Once you are setup, refer to the information in this section for how to open a chart for equities:
File Menu: Find Symbol (File)
