Date/Time: Wed, 12 Feb 2025 15:51:30 +0000
Time in Force: All or None
View Count: 659
[2020-11-06 00:44:39] |
ondafringe - Posts: 298 |
Looking over the docs for setting up "Time in Force" in ACSIL: Automated Trading From an Advanced Custom Study: s_SCNewOrder Structure Members However, I do not see "All or None" listed. Is this not available using code? |
[2020-11-08 00:43:08] |
This Time in Force for ACSIL will be supported in the next release but we do not know whether it will be supported by the particular exchange or trading service you are trading on. If not, the order will get rejected.
[2020-11-08 01:34:50] |
Okay, thanks for the response.
