Date/Time: Wed, 12 Feb 2025 16:10:35 +0000
Moving data files to new instance for simulated trading
View Count: 656
[2020-11-05 20:48:40]
User910795 - Posts: 35
I am using New Instance 1 for simulated trading, and have found that not all of the study collections load properly in the new instance. Consequently, I am "updating" them in the sub instance and it is time consuming. It appears to me that I can copy the DLY, CHT, SCID, AND perhaps the twConfig files from the main data folder and simply paste them into the new sub instance data folder and this may get everything "right". Any thoughts or input on this....
[2020-11-05 22:38:23]
John - SC Support - Posts: 37893
Refer to the information at Step #5 in the following documentation section. It is about copying Sierra Chart to a different installation, but the information applies to a sub-instance.
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
