Date/Time: Wed, 12 Feb 2025 16:07:01 +0000
2 different brokerage
View Count: 455
[2020-11-05 20:39:38] |
Balolah - Posts: 4 |
Hi, I would like to connect my SC with 2 different brokerage firms. Started from 2 separate folders. One would be the AMP, where I would trade with Futures. The second would be the Interactive Brokers, where I would trade with FX. Which data service should I choose? a, Denali for Sc Order Routing Service b, Denali for All service Thank you! |
[2020-11-05 22:36:08] |
John - SC Support - Posts: 37892 |
With your AMP account, are you going to be trading using CQG or the Sierra Chart Order Routing Service? If you are using CQG, then you would select the option Denali Exchange Data Feed for All Services. If you are using the Sierra Chart Order Routing Service, then you would select the Denali Exchange Data Feed for Order Routing Service.
