Date/Time: Fri, 18 Sep 2026 18:24:01 +0000
Expectancy number doesnt change when switching p/l format
View Count: 726
| [2020-11-05 18:33:42] |
| User589122 - Posts: 7 |
Hi, I don't know if this is by design but the expectancy value is only correct when you use currency value as p/l format. When you switch p/l format to points or ticks etc. it won't change to the correct format (see attachment). Best regards, Maurice |
| Attachment Deleted. |
| [2020-11-05 19:27:55] |
Yes it is by design.
| [2020-11-06 17:34:16] |
Thanks for the quick reply! Wouldn't it make sense if it's shown in the p/l format that is selected just like all the other fields? Now it's a bit confusing. I know I can download it to excel and do the calculation myself but it would be really nice to have it shown automatically in the chosen p/l format in Sierra Chart.
