Date/Time: Wed, 12 Feb 2025 15:42:13 +0000
Auto centering...
View Count: 852
[2020-11-05 18:23:34]
User629089 - Posts: 93
Is there a way to have a chart always centered? Often prices on a footprint chart in particular when moving quickly go above the chart high/low borders. I tried to figure it out through the documentation but was unable to.
Thanks...
[2020-11-05 19:25:48]
John - SC Support - Posts: 37891
If you are wanting to have the chart automatically adjust the scale so that as you scroll through the bars, the scale will keep all bars within view, then you want to use Automatic Scaling. Refer to the information here:
Chart Scale and Scale Adjusting: Automatic (Scale Range)
If you want to keep the chart static, so the scaling does not adjust as you move through the chart, then refer to the following:
Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range
In general refer to the information on that Scaling page for the various options available.
