Date/Time: Wed, 12 Feb 2025 15:47:36 +0000
Not receiving data from Denali
View Count: 490
[2020-11-05 15:15:31]
User270982 - Posts: 2
I am not able to receive data from Denali today. I am running version 2109 and have not had an issue with this data service until today. What are some things I can try to remedy this?
Thanks.
[2020-11-05 15:55:17]
To update this topic. It seems I can get data from Denali but not using the interactive broker symbol. If I use the ESZ20-CME symbol everything works well but I don't seem to be able to use IB to execute that symbol. When I update that symbol to the IB globex symbol I seem to be getting data only from IB. What is the work around for this? And why did it start happening today?
Thanks.
[2020-11-05 16:43:00]
John - SC Support - Posts: 37891
You have signed up for the Non-Professional CME exchanges, which means that you need to connect to your live, funded futures trading account at the beginning of each month to qualify for the lower-priced exchange fees. You have not connected to your trading account yet this month. Refer to the following:
[2020-11-05 21:06:51]
You also need to update to the current version of Sierra Chart. You are running a significantly older version. Update instructions:
