Date/Time: Wed, 12 Feb 2025 16:08:05 +0000
Importing a text file remove some data
View Count: 436
[2020-11-05 14:14:09]
GravisHTG - Posts: 306
I wonder why , I create a text file and it remove some entry i put in. The file in question , i upload it. Is it because of duplicate ?
attachmentA.txt - Attached On 2020-11-05 14:13:32 UTC - Size: 158 B - 247 views
[2020-11-05 16:25:27]
John - SC Support - Posts: 37892
Yes, it will automatically remove duplicates in the file. Refer to the information here:
Changing the Symbol of a Chart: Importing a List of Symbols
