Date/Time: Wed, 12 Feb 2025 15:46:27 +0000
Subinstance cannot disable Safe Mode
View Count: 467
[2020-11-05 06:22:46]
nixon - Posts: 6
I had a problem with an ACS.
So I activated safe mode and corrected the problem.
When I disabled the safe mode,
only main instance and subinstance #3 were able to return to normal mode.
Subinstance #2 is still in safe mode.
I have done the steps in
Sierra Chart - Software Login Instructions: Using Safe Mode
But still #2 still in safe mode.
[2020-11-05 16:16:13]
John - SC Support - Posts: 37891
You need to turn on/off Safe Mode per sub-instance. When you start Sub-Instance #2, are you selecting Cancel and then clicking in the box to disable Safe Mode? Is that not working for some reason? What exactly is happening when you do this?
