Date/Time: Wed, 12 Feb 2025 15:57:50 +0000
Could not change stop or limit in live trade
View Count: 490
[2020-11-05 04:39:28] |
User984260 - Posts: 1 |
I had a position in profit when AMP Futures deducted the commissions and fees from my account, which took it below full margin requirement. When I noticed my "Available Funds For New Positions" was a negative number, I tried to adjust the stop and limit on the DOM, but they would revert back to their previous location. I hit "Flatten" but that only removed my stop and limit. I then hit "Flatten" again and the position closed. 1. Should I still be able to adjust stops and limits in this unusual situation? 2. I thought that if I have an open position, or several open positions and I hit "Flatten", all positions should be closed and all pending orders should be cancelled. Is this correct? Thanks! |
[2020-11-05 05:23:06] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2020-11-05 05:54:41] |
User732675 - Posts: 1 |
Done.
[2020-11-05 09:49:02] |
We see you are using CQG. 1. We do not know the answer to this. We do not think you would have this problem when using the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service We are fairly sure you would not. 2. The solution to this is explained here: Basic Trading and the Trade Window: Rejected Market Order When Using Flatten or Reverse Because of Position Limit Exceeded Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
