Date/Time: Wed, 12 Feb 2025 16:02:35 +0000
How to change the color of the cumulative delta bar study?
View Count: 674
[2020-11-04 22:54:06]
selest - Posts: 1
I have changed the color in Graphic settings for the up and down fill but that only changes the color of the instrument bars at the top of the chart but not the bars for the study at the bottom
[2020-11-04 23:12:22]
User714262 - Posts: 8
I'm not 100% sure if this is correct but:
Go to your chart -> Press F6 -> Go on "Settings" on your "Cumulative Delta" study -> "Subgraphs"
[2020-11-05 15:25:26]
John - SC Support - Posts: 37891
As mentioned above, you need to change the colors of the Subgraphs for that study. Refer to the information here:
Chart Studies: Subgraphs Tab >> Color
[2020-11-05 20:24:20]
For more information refer to:
Color Settings for Graph Draw Types
