Date/Time: Wed, 12 Feb 2025 15:49:17 +0000
Micro Emini pricing
View Count: 616
[2020-11-04 19:42:48] |
User673695 - Posts: 1 |
I have a new account and started SIM trading symbol MNQZ20, the micro nasdaq. My SIM trades are registering $5 per tick not .50 cents. I have ENQZ20 and MNQZ20 in the same chart book. Can you tell me what I'm doing wrong?
[2020-11-04 22:23:04] |
Check this setting: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
