Date/Time: Sun, 08 Sep 2024 00:23:14 +0000
Last 60 second volume information
View Count: 993
[2014-02-12 23:45:51] |
Moti - Posts: 63 |
Hello, I will like to display / alert if (Ask volume -Bid volume >=100 ) at the last 60 seconds Any time bar will recount every new bar... Can it programmed in ACSIL ? Thank you, Moti |
[2014-02-14 01:02:45] |
We see no reason why not, but the details you will need to work out.
