Date/Time: Wed, 12 Feb 2025 18:22:41 +0000
[User Discussion] - Average Daily Range
View Count: 1044
[2020-11-04 14:47:08]
User00111 - Posts: 111
How can I create the Average Daily Range of the last 5 days in text format ?
A.
imageAverage Range daily.png / V - Attached On 2020-11-04 14:46:58 UTC - Size: 17.52 KB - 244 views
[2020-11-04 15:27:11]
John - SC Support - Posts: 37910
Refer to the following Study Collection for how to display the text in general, then you would just need to repeat the display using the option for Subgraph Columns Back set to an appropriate value:
https://www.sierrachart.com/AdditionalFiles/TextDisplayOfAverageTrueRange.StdyCollct
Refer to the following for how to use a Study Collection:
How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection
[2020-11-07 18:25:28]
I tried to put the Daily range on the 15 Minute chart ... but it doesn't work correctly ...
Is it possible that functions only on daily bar charts?
A.
[2020-11-09 06:16:56]
Refer to the documentation for that study here:
Average Daily Range
You need to use this study to reference that Study data on a Historical Daily Chart:
Text Display For Study from Chart
