Date/Time: Wed, 12 Feb 2025 16:01:26 +0000
Get Moving Average values from other symbols and timeframes
View Count: 537
[2020-11-04 12:51:04] |
László Csipkés - Posts: 8 |
Dear Support, I'd create a study to check the exponential moving average value on about 50 symbols (on M1, M5 and M15 timeframes). Is there any way to get those values in a single study without open every chart manualy? BR Laszlo Date Time Of Last Edit: 2020-11-04 14:56:31
[2020-11-04 13:45:39] |
Refer to: Changing the Symbol of a Chart: Using the Associated Watch List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-05 14:10:49] |
Ok, I tried it but the sc.DataFile = "QQQQ.scid"; chenged the symbol of the chart. I dont want to change this every time, because I need to show some information on the chart with labels. Is there any way to work with as much symbol as I need without changing the symbol of the chart or open every chart manually? I need the bar list of every symbol I check with my study on every bar period. |
[2020-11-05 16:21:09] |
John - SC Support - Posts: 37891 |
You would need to open a chart for each symbol and timeframe you are wanting. You can then overlay the information from those charts to the one you are watching using the Study/Price Overlay study. Refer to the information here: Study/Price Overlay Study Once you have the charts setup the way you want, you can then hide those charts so they will not be as bothersome. Refer to the information here: Window, CB and CW Menus: Hide Window (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-05 16:31:12] |
Thank you for your answer, Is there any method to open new charts from the study? BR |
[2020-11-05 16:48:02] |
Refer to the following: sc.OpenChartOrGetChartReference() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-05 18:32:54] |
Thank you, It works! Date Time Of Last Edit: 2020-11-05 18:37:02
