Date/Time: Wed, 12 Feb 2025 17:57:57 +0000
dofferent color evening session TPO profile
View Count: 1134
[2020-11-04 10:39:19] |
User884550 - Posts: 149 |
could not find an option to color evening session differently, is this supported? Can it be added? |
[2020-11-04 11:39:37] |
Yes this is fully supported. And is explained here: Time Price Opportunity (TPO) Profile Charts: Displaying Separate Profiles for Day and Evening Sessions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-06 14:20:48] |
User288063 I dont follow your comment, support reply #2 has solved exactly what I was asking for
[2020-11-09 11:26:51] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
