Date/Time: Wed, 12 Feb 2025 15:55:18 +0000
Trailing stop till break-even
View Count: 982
[2020-11-04 09:07:24] |
manfretto - Posts: 117 |
Hello, is it possible to use Step Trailing Stop till break-even only and once trailing stop reaches entry price it is continued with manual adjustments by a trader? |
[2020-11-04 12:37:09] |
The closest that is available is to use the Move to Breakeven for Stops functionality: Attached Orders: Move to Breakeven for Stop This is all that is available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
