Date/Time: Wed, 12 Feb 2025 16:16:19 +0000
Get 0 when using
View Count: 482
[2020-11-04 09:07:23] |
User763472 - Posts: 22 |
Dear Sir/Madam, I was using the function "sc.GetStudyArrayUsingID" to get the study arrays from the same chart. Through Visual C++, I found out that when not using "replay", I correctly got all the data. While using "replay", I received "0" for all the data. FYI, I set "sc.CalculationPrecedence = LOW_PREC_LEVEL;" in Default part already and also enabled "Use Controlled Order Chart Updating" in the General Setting pannel. I tried other functions such as "sc.GetStudyArraysFromChartUsingID" and got the same result. I need to use "replay" to back-test trading systems. Could you please help on this? Thanks! Best regards, Zeyu |
[2020-11-04 13:36:08] |
This might be due to study calculation order: Chart Studies: Study Calculation Precedence And Related Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-04 13:36:20
