Date/Time: Mon, 25 Nov 2024 14:44:16 +0000
Continuous Futures Back Adjustment
View Count: 1168
[2014-02-12 22:22:50]
cazeek - Posts: 33
I've been trying to get the continuous futures back adjustment feature working, and I'm not sure where I'm going wrong. No matter what contract I open, it only shows the last few days' data, and the message log has a series of:
CLH14 [CB] Daily #1: Back adjust amount for symbol CLZ13 is 0. | 2014-02-12 22:20:32
CLH14 [CB] Daily #1: Back adjust amount for symbol CLF14 is 0. | 2014-02-12 22:20:32
CLH14 [CB] Daily #1: Back adjust amount for symbol CLG14 is 0. | 2014-02-12 22:20:32
Can you explain what I'm doing wrong please? Thanks very much
[2014-02-12 23:51:13]
What Data or Trading service are you using?
Could you do the following:
Select File >> Open Historical Chart.
Delete the three most recent CL?## Daily data files that you see.
Go back to the CL daily chart and select Chart >> Reload and Recalculate.
[2014-02-14 00:34:33]
You may also need to either Update or Reset the Symbol Settings. This is documented here:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings
[2014-02-14 00:35:35]
cazeek - Posts: 33
Thank you- I realized the issue had something to do w/ the Sierra data.. when I switched to interactive brokers data, the problem was solved.
