Date/Time: Wed, 12 Feb 2025 16:06:07 +0000
draw rectangle instead of line
View Count: 1523
[2020-11-04 07:38:17]
User884550 - Posts: 149
Is there any drawing style that can be used to draw specified width extended rectangle, ie zone, instead of just lines for the study?
[2020-11-04 13:46:59]
Yes. There are various draw styles that fill in area between two Study Subgraphs:
Chart Studies: Subgraphs Tab >> Draw Style
[2020-11-04 13:50:08]
i dont want to fill between subraphs, but i want one subgraph be drawn as transparent zone with subgraph value in the middle
[2020-11-04 15:22:39]
John - SC Support - Posts: 37891
You would need to use the Arithmetic studies in combination with the Study Subgraphs Reference and use the Transparent Fill styles that were referenced above.
The following Study Collection does this for the ATR, which you can use as informational or as a basis for what you want to do:
https://www.sierrachart.com/AdditionalFiles/FillOpenRange.StdyCollct
Refer to the following for how to use a Study Collection:
How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection
[2020-11-06 13:28:00]
looks a little complicated,
is it possible to add an option for a transparent dash draw style?
then it would be possible to draw think transparent lines which would solve a lot of issues for traders using trading zones
