Date/Time: Wed, 12 Feb 2025 16:18:58 +0000
ACSIL adjust chart position before screenshot
View Count: 454
[2020-11-03 23:57:15] |
User818063 - Posts: 16 |
Hi Can the chart be repositionned in time using ACSIL in order to take a screenshot (using sc.SaveChartImageToFile / sc.SaveChartImageToFileExtended ) ? For ex, set the chart to a certain date/time and then take the screenshot ? Thx. |
[2020-11-04 01:42:15] |
You can use this variable for that ahead of time: ACSIL Interface Members - Variables and Arrays: sc.ScrollToDateTime Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
