Date/Time: Wed, 12 Feb 2025 16:18:22 +0000
Question about Drawing from another chart.
View Count: 470
[2020-11-03 19:47:44] |
GravisHTG - Posts: 306 |
After the new chart copy the drawing , How can we make it that we cannot select them in the secondary chart ? thanks |
[2020-11-04 00:41:36] |
What you want to do is supported. Refer to this option: Chart Settings: Allow Modification of Chart Drawings from Other Charts (Chart >> Chart Settings >> Chart Drawing menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
