Date/Time: Wed, 02 Apr 2025 07:56:18 +0000
[Locked] - Notice: Replacement for CBOE Indices Historical Daily Data
View Count: 6786
[2021-02-15 02:14:34] |
SC Support - Posts: 1950 |
Thank you for your feedback.
[2021-02-22 04:37:39] |
User722856 - Posts: 78 |
@SC: Regarding #19 and #21: I posted an alternative solution for CBOE and other Indices, in the thread bellow, for you to consider. Post #5: Google Finance Data Service - Feed doesnt work thnx Date Time Of Last Edit: 2021-02-22 04:38:52
[2021-06-20 14:30:17] |
User365411 - Posts: 193 |
We will shortly have the CFE (VIX Futures) raw data feed, we are speaking to the same guys that offer the CBOE Indices that you have listed, we will investigate to see if there is something larger to be done with them. You will be able to see announcements on the Support Board as progress is made. Thank you
Now that the CFE feed is out do you have any good news about the CBOE Indices implementation (historical and intraday delayed data) (post #21)? I know that you are mainly focused on futures data but indices levels are very important for technical analysis, often more important than future levels. TY Date Time Of Last Edit: 2021-06-20 14:30:52
[2021-06-21 18:16:02] |
Sierra_Chart Engineering - Posts: 19044 |
We do plan to offer the NASDAQ global indices data feed, which should have equivalents to CBOE indices. Real-time CBOE Indices is currently available through the SC Exchange Data Feed: Sierra Chart Exchange Data Feed Other than this, there are no other plans. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
