Date/Time: Wed, 12 Feb 2025 15:52:38 +0000
FLatten various positions error
View Count: 552
[2020-11-03 18:20:45] |
User202740 - Posts: 12 |
Hi, I'm not sure if trading errors should be ask or not but this is the second time that happens to me. When I have several positions opened and I want to flatten all them, the 1st time clicking the button it appears an error and then I need to press again to close all the trades. Somedays I'm scalping and 1 second of difference can turn a good trade into a bad trade. Is this nromal? |
[2020-11-04 13:40:55] |
Refer to: Basic Trading and the Trade Window: Rejected Market Order When Using Flatten or Reverse Because of Position Limit Exceeded Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-05 17:08:14] |
So do you mean that enabling this option: "Hold Market Order Until Pending Cancel Orders Are Confirmed" the problem will be fixed?
[2020-11-05 20:54:29] |
Yes.
