Date/Time: Wed, 12 Feb 2025 15:46:13 +0000
Net P&L Inaccurate
View Count: 558
[2020-11-03 17:05:00] |
User148596 - Posts: 217 |
My net P&L is way off. Not sure why this is happening. It's the trade window on my DOM.
[2020-11-04 12:38:23] |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-05 16:32:53] |
Sorry I can't seem to figure this out. Any way we could jump on a phone call? Thanks!
[2020-11-05 21:19:03] |
The easiest thing to do is when you are flat for the symbol of the chart, set this setting: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) To the current Date and Time. Also make sure this option is enabled: Chart Settings: Filter Initial Fills Which Are Part of Existing Position (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
