Date/Time: Sun, 04 Oct 2026 03:42:20 +0000
is there acsil functionality to scroll to a previous bar index?
View Count: 2647
| [2020-11-03 09:49:15] |
| ochocinco - Posts: 29 |
I'm starting this question with support in case there is some acsil functionality and I missed it. If there isn't then this becomes a user/programming help request. Given a chart with 1000 bars, using the scroll bar I can scroll back so that bar 500 is the last visible bar. Is there acsil functionality which can set the value of the last visible bar? thanks, |
| [2020-11-04 12:21:39] |
Have a look at this variable: ACSIL Interface Members - Variables and Arrays: sc.ScrollToDateTime This function should not be needed but we also want you to be aware of it: ACSIL Interface Members - Functions: sc.GetContainingIndexForSCDateTime() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-04 12:22:52
