Date/Time: Thu, 13 Feb 2025 20:11:34 +0000
sc.TradeServiceAccountBalance taking account number as argument
View Count: 607
[2020-11-03 08:30:08] |
User869657 - Posts: 31 |
Hi SC team, Apologies if I missed it but is there a function similar to sc.TradeServiceAccountBalance that would take the account number as parameter and return its balance ? The issue with sc.TradeServiceAccountBalance is that we have to duplicate the charts (one per account) when we want to put one algo on different accounts. If none exists, is it please possible to create it ? Thanks a lot |
[2020-11-05 20:13:29] |
Could you please let me know about the above please ?
[2020-11-06 14:06:39] |
We will have to add a new function for this.
[2020-12-25 18:17:42] |
Hello SC team, Could this item be picked up please ? Thanks a lot |
[2020-12-26 09:45:34] |
User90125 - Posts: 715 |
+1
[2020-12-26 22:15:59] |
This has already been released: sc.GetTradeServiceAccountBalanceForTradeAccount() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
