Date/Time: Wed, 12 Feb 2025 15:45:30 +0000
Only extend POC on TPO with a certain number of TPOs or greater
View Count: 604
[2020-11-03 07:15:09] |
User608413 - Posts: 12 |
Is there a way to only show/extend POCs with 10 TPO count or higher on the TPO chart? If not, could this functionality be added in?
[2020-11-04 12:06:31] |
No this is definitely not planned. Have a look at the Peaks and Valleys functionality to see if that would be helpful: Time Price Opportunity (TPO) Profile Charts: Draw Peaks and Valleys Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-04 15:29:25] |
I don’t see a way to do what I’m asking using that. Can you explain? Is there a way to have it at least display the POC TPO count? Otherwise I see no way to do it besides manually counting. |
[2020-11-05 20:52:04] |
What you want is not supported. To display the TPO at each price level, refer to this Input: Time Price Opportunity (TPO) Profile Charts: Display Total TPO Count Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-05 20:53:05
[2020-11-06 04:49:45] |
Would it be possible to code this on my own?
[2020-11-06 12:36:39] |
Yes you can do this using ACSIL: Advanced Custom Study Interface and Language (ACSIL) There is this function which allows you to get the data for each price level of a TPO profile: sc.GetVolumeAtPriceDataForStudyProfile() This includes the number of TPOs at each price level. And refer to: sc.AddLineUntilFutureIntersectionEx() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
