Date/Time: Wed, 12 Feb 2025 15:55:36 +0000
[Programming Help] - endlessly growing indicator value
View Count: 558
[2020-11-03 04:57:25] |
jomo88 - Posts: 47 |
My custom indicator keeps growing for the most recent value... but only when futures are being used as the main chart. I only plan to use it during the regular trading hours, so I have the chart setting times to restrict that. When I run my indicator now, the most recent value, which does not need to update (it is night time now), keeps growing! See attached When I have the index feed IUXX or just a stock like MSFT, the problem does not occur. I can't find whats missing in my code. Anyone experience this? Thanks |
[2020-11-03 15:06:05] |
Just tested, it also happens during regular trading hours when my chart settings have new bars coming in within the selected session times.
[2020-11-06 17:24:41] |
For anyone who might be searching for this later on... My problem was I was using statements like this... sc.Subgraph[0][BarIndex] += 1.0; For example... for (int BarIndex = sc.UpdateStartIndex; BarIndex < sc.ArraySize; BarIndex++) { if (blahblah > 0) { sc.Subgraph[0][BarIndex] += 1.0; } } My solution was to create a temporary holder for sc.Subgraph[0][BarIndex] and add it after the if statements float temp_sum; for (int BarIndex = sc.UpdateStartIndex; BarIndex < sc.ArraySize; BarIndex++) { if (blahblah > 0) { temp_sum += 1.0; } sc.Subgraph[0][BarIndex] = temp_sum; } Date Time Of Last Edit: 2020-11-06 17:26:16
