Date/Time: Wed, 12 Feb 2025 16:04:57 +0000
Data feed is behind 10 minutes
View Count: 549
[2020-11-03 02:38:41] |
User712062 - Posts: 14 |
Hello Good afternoon . I would like to know why my data is running 10 minutes behind.I had deposited already in the morning . Thanks in advance
[2020-11-03 03:28:53] |
This message is on your account: The Denali Exchange Data Feed has been canceled on your account due to Insufficient balance to activate service. A balance of at least 51.2 USD is required for AC125375 to pay for all required services. Current balance for account (**) is 0.40 USD. Make Payment For 50.8 USD:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit&Amount=50.8 . You can reactivate the recently deactivated services from this page: https://www.sierrachart.com/UserControlPanel.php?page=RecurringServices#RecentlyDeactivatedRecurringServices If you have already reactivated the data feed, then ignore this message. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-03 14:24:24] |
I dont understand. That is my balance since yesterday Services Balance: 52.40 USD - Make Payment. Thanks in advance
[2020-11-03 16:29:15] |
John - SC Support - Posts: 37891 |
We see that you have gotten the data feed setup again, so you are good with respect to that. What happened was that you deposited the funds into your account on November 2, 2020. The Exchange Data Feed renews on the 1st of every month, therefore you need to ensure that you have enough funds in your account prior to the 1st of the month for the data feed. Note that the Sierra Chart usage time works on a different time scale, which, if you pay monthly, is every 31 days. It is not precisely monthly like the data feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
