Date/Time: Wed, 12 Feb 2025 15:46:45 +0000
Question
View Count: 425
[2020-11-03 02:36:01]
User825655 - Posts: 1
Hello!
I usually trade ES futures but I wanted to view the chart for 6AZ20. I thought I could simply swap out the symbols and the chart would populate. A chart loads but there is no range bars. Not sure what setting I need it to be at? Is there a reason I can't log into symbol 6AZ20.
Please advise.
[2020-11-03 06:37:14]
Is there anything displayed in the chart at all?
Make sure you are using the correct symbol and you get it through the Find Symbol window:
File Menu: Find Symbol (File)
