Date/Time: Wed, 12 Feb 2025 16:03:47 +0000
pack 5 to pack 3
View Count: 482
[2020-11-03 00:45:17] |
User599655 - Posts: 3 |
Hello, I had switched to Pack 5(trial) by mistake. How can I go back to Pack 3 (free version). Don't want to loose my current chart/Dom settings. Thank You.
[2020-11-03 06:28:11] |
Your Sierra Chart account is currently on Service Package 3. So there is nothing you need to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-03 06:28:17
