Date/Time: Wed, 12 Feb 2025 16:00:05 +0000
Control bar font color
View Count: 533
[2020-11-02 21:32:18] |
User231861 - Posts: 9 |
Hi. Please is it possible to change font color of Control bar. I see that I can change font size, buttons background color.. But not font color. Thanks for your help! |
[2020-11-02 21:42:34] |
John - SC Support - Posts: 37891 |
Refer to the following setting and the one after it: Graphics Settings: Control Bar: Enabled Button Text And refer to this section here for instructions to use the Graphics Settings window: Graphics Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-02 22:23:22
