Date/Time: Wed, 12 Feb 2025 15:54:02 +0000
Volume Value Lines Study
View Count: 627
[2020-11-02 19:01:05] |
User665173 - Posts: 8 |
The Volume Value Lines are not working properly. When I place them on a chart, with a look back period of 1 day, they give me a look back period of 5 days. If I place the TPO Value Lines study on the same chart, I get the expected 1day look back and not 5. They have worked properly for years. I reloaded the program and have the most recent update. I have the same problem on my other computer. |
[2020-11-02 19:56:05] |
John - SC Support - Posts: 37891 |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2020-11-02 22:26:58] |
We recommend referring to the documentation for the Input settings that you are using: Volume Value Area Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-03 06:10:39] |
We did see your other posting and that is not proper to make a posting like that. And that has been deleted. Furthermore, we have a policy that you need to log in with your paid Sierra Chart account to this Support Board. Your account is expired. And our documentation is very thorough. In this case, study Inputs are well documented. We thought the issue related to the study skipping back to a time period where there was sufficient data available for the time period being referenced, and there usually is a percentage setting controlling this. After we made our post above, we began to do a thorough review of Volume Value Area Lines study to see exactly how it works and make sure the documentation explains the functionality. The study implementation took more time to understand and we did not make any updates and we also did not identify any problem either like you describe. At this point the first step is to follow the instructions at post #2. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-03 06:27:04] |
We have now completed the review of the Volume Value Area Lines study. The documentation has been updated for the "Reference n Periods Back: " Input: Volume Value Area Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-04 05:28:06] |
We did see your other posting. Provide the chart with the Volume Value Area Lines study by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart You first need to log into this Support Board with Help >> Support Board from within your Sierra Chart installation. You cannot use the expired account to post. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-04 05:28:46
