Date/Time: Wed, 12 Feb 2025 16:10:00 +0000
which denali exchange feed should i choose?
View Count: 502
[2020-11-02 18:33:50]
HippoTown - Posts: 3
I am setting up SC to use TAS market profile as an add-on. I am not going to trade from SC. I only need top-of-book tick-by-tick data for TAS indicators to work. Do i need the SC Order Routing Service or the Denali Exchange Data Feed for other services?
[2020-11-02 19:54:40]
John - SC Support - Posts: 37892
What trading service are you going to use to validate that you have an account in order to qualify for the lower-priced Non-Professional exchange fees?
[2020-11-02 19:58:31]
Optimus futures / amp clearing
[2020-11-02 20:01:57]
Which service are you using with AMP - CQG or the Sierra Chart Order Routing?
[2020-11-02 20:04:12]
Rithmic
[2020-11-02 20:11:17]
Then for the Denali Exchange Data Feed, you want to select the option "Denali Exchange Data Feed for All Services", which is $25.00 USD per month.
Since you only need the Top of Book data, you will want to select the exchange(s) you need that do NOT include market depth.
Just keep in mind that in order to qualify for the non-professional exchange fees, you will need to connect to your trading account at least once a month if you are not going to be connected all the time. Refer to the information here:
[2020-11-02 22:41:53]
Rithmic is not really the best choice for verifying you have a trading account. There can be technical complications with that. We recommend using the Sierra Chart Order Routing Service:
Sierra Chart / Trading Technologies Futures Order Routing Service
