Date/Time: Thu, 13 Feb 2025 02:51:43 +0000
+ and - buttons don't increment resting order value
View Count: 594
[2020-11-02 16:37:28] |
User502498 - Posts: 33 |
When I click in the quantity and then click +, it doesn't increment by 1, it just goes black. Ver 2180 |
[2020-11-19 17:36:07] |
Hi. I never heard back on this.
[2020-11-19 18:30:21] |
John - SC Support - Posts: 37916 |
Upgrade to the latest release as there has been some work on those dialogs, and that particular one for the quantity has changed.
[2020-11-19 18:34:30] |
I can't yet since you are making us recompile ASCIL code as well.
[2020-11-21 12:50:16] |
You can install two installations of Sierra Chart until you get your custom studies recompiled. If you have the source code this is not a problem. Refer to: How to Build an Advanced Custom Study from Source Code You can use a prior version for your custom studies and an up-to-date one that you use for trading. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
