Date/Time: Wed, 12 Feb 2025 16:20:18 +0000
Alert option text box
View Count: 606
[2020-11-02 15:22:16] |
Tonkadad - Posts: 235 |
Is there a way to have a text box/message pop up on screen as an alert? It would be useful to be able to create user definable messages i.e. when MA's cross a popup box "Cross to the upside, possible long entry" |
[2020-11-02 17:49:42] |
John - SC Support - Posts: 37895 |
Refer to the following: General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-03 15:52:36] |
Thank you
