Date/Time: Fri, 18 Apr 2025 06:23:46 +0000
Copy Study To Another Chart
View Count: 2651
[2020-11-02 14:41:22]
User443403 - Posts: 9
is it possible to copy a study with parameters set from a sub-chart to another chart?
For example I have numbers bars calculated values configured with only the values I use set to display in chart region 2. I would like to copy that study with my parameters to another chart.
thanks in advance
[2020-11-02 17:48:00]
John - SC Support - Posts: 39353
There are a few ways to do this, but there is not a direct copy utility to copy the study to another chart.
Option 1 (recommended method) - Study Collection: Save the study as a Study Collection, then apply this to the other chart. Refer to the information here:
Study Collections: Introduction
Option 2 - Duplicate Chart: Duplicate the chart that has the study on it, then change the symbol (or other items) as needed. Refer to the information here:
Using Chart Templates: Duplicating Charts / Template Charts
Option 3 - Study Defaults: Set the study as you want and save it as the defaults for that study. Then apply that study to the other chart, where it will be added with those default settings. Refer to the information here:
Chart Studies: Using Custom Default Study Settings
[2024-10-21 16:16:02]
User318857 - Posts: 16
Hi there,
the open price line is not precise for me because I have candles in volume.
So I duplicated my VWAP-day chart to move it to M1 and apply a line with the precise open price.
Is it possible to copy this study onto my WVAP-day volume chart?
In other words, just as the drawings are copied, can I do it with a studie?
[2024-10-21 17:31:36]
Refer to the following:
Study/Price Overlay Study
[2025-03-24 11:47:37]
User556049 - Posts: 22
I am still wondering why anchored VWAP is not as easy as in trading view? This is an advanced platform but the A-VWAP which you can use free of cost in trading view is simple to use and perfect. Here it takes couple of hours to set it and know how to use it and also need to search youtube video or somewhere to find it. Apart from that, you need to set up 1 AVWAP to add and another set up to delete and if I want to add more than 1, you need to set up again and so on. This is not fun. Or if there is an easy way, just let me know if I am missing it by chance.
Date Time Of Last Edit: 2025-03-24 20:55:25
[2025-03-24 16:04:52]
What tool are you using for the Anchored VWAP? Have you tried using the "Drawn Volume Profile" tool?
Volume By Price Study: Draw Volume Profile
[2025-03-24 20:08:50]
I have checked anchored VWAP by drawing a volume profile and also the one that you customize and add VWAP+. But it should be like in tradingview, you can just click once and add as many as you want and delete when you want in one click. First click on the tools, and then search for volume profile took and select the chart area to draw volume profile and then go to studies and lot of things. I have seen the video how it is done and also I have seen the other way which is under studies and add customs study and so on. It is very complicated. As I said , in trading view, it can be done in one click.
I want to do back testing to few hundreds charts, so this is tedious and time consuming process..... I am very unhappy about it and I am sure that there are many other people who feel like me.
