Date/Time: Wed, 12 Feb 2025 12:49:51 +0000
Denali Trial
View Count: 640
[2020-11-02 14:20:59] |
User934886 - Posts: 42 |
Hello, I would like to start the one month Denali trial fro my account starting today. thank you [information removed for privacy] Date Time Of Last Edit: 2020-11-02 15:20:40
[2020-11-02 15:22:28] |
John - SC Support - Posts: 37891 |
Just follow the Setup Instructions for the Denali Exchange Data Feed starting here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* The remainder of the month in which you activate the data feed along with the exchange(s) is free. There is nothing special you need to do. You will then be charged the full amount on the first day of the next month (December 1, 2020, assuming you activate during November). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-02 15:39:23] |
Is first month of Denali data free if i set it up thru my broker Amp Futures?
[2020-11-02 16:08:44] |
You would need to ask AMP that question.
