Date/Time: Wed, 12 Feb 2025 12:59:16 +0000
RESOLVED: Last 32-bit Version
View Count: 927
[2020-11-02 12:52:30]
Lesmond - Posts: 22
Which is the last 32-bit version which runs on Windows 7? Here are my random test results:
v2133 - ok
v2146 - ok
v2186 - won't start
v2191 - won't start
I can see that in case of the last two versions listed above the icon of SierraChart.exe file is different and the file itself has the size of only 1846 KB, so it is obviously a fake startup file. However, according to the documentation, both 32-bit and 64-bit versions are still available:
Software Download: Difference Between 32 and 64-bit Versions
[2020-11-02 13:01:48]
Ackin - Posts: 1865
Somewhere v2168 - v2176
v2177: The 32-bit version of Sierra Chart is not included with this release.
[2020-11-02 13:17:43]
Lesmond - Posts: 22
Thanks. I have marked it RESOLVED.
