Date/Time: Sun, 08 Sep 2024 00:32:22 +0000
DOM functionality
View Count: 1034
[2014-02-12 20:44:12] |
User59550 - Posts: 6 |
I am using the DOM to execute my trades and I am trying to set it up in the way it will work best for me and I would like to: 1) ...see the price instead of the ticks 2) ...know what is the middle box between the three boxes under the "Pos Qty@price" 3) ...remove the "confirm order" window that appear anytime I place an order/limit 4) ...be able to move/drag the limits I set on the DOM with 1 click 5) ...when I execute the order/limits on the DOM, I would like to see on my chart, the lines related to my order/limits I set from the DOM... and if possible, make those line to be able to move/drag up/down in the chart |
[2014-02-14 00:32:24] |
1. What exactly are you referring to here? In the ladder of prices on the Trade DOM there are only prices. If you are referring to the Open Profit/Loss for the current Position, then changing the display format is documented here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#ProfitLossDisplay 2. This is the Open Profit/Loss: https://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#OpenProfitLoss 3. This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#MenuButton 4. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#ModifyingOrdersOnTheChart 5. You just need to enable Trade >>Chart Trade Mode On for the chart. It is documented here: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#ChartTrading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-14 00:33:19
