Date/Time: Wed, 12 Feb 2025 15:59:40 +0000
Zig Zag Using first touch of a price as the turning point
View Count: 548
[2020-10-31 18:51:12] |
User682444 - Posts: 12 |
If price hits an extreme point for the run, bounces (less than the reversal amount) and then hits the same price again (double top/bottom), the turning point for the ZIG Zag will move from the first touch to the subsequent touch. I would like the turning point to remain as the first touch of the extreme. Any subsequent touch is not a new High or Low but is indicative of failure and will indicate probable divergence. Could this different way of recognizing the extreme be an option in the option list? |
[2020-11-02 22:22:27] |
You have to modify the study to meet your requirements. For instructions: How to Build an Advanced Custom Study from Source Code This is not something we would add. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-02 22:22:50
