Date/Time: Wed, 12 Feb 2025 13:01:46 +0000
Missing TPO profiles
View Count: 771
[2020-10-31 10:36:37] |
Hayden Glenn Barnes - Posts: 7 |
Hi, Iv jut noticed that all my TPO profile are no longer visible on any of my tpo charts, this is the case for all of my chart books, drawing are still mapped over but I'm unable to work out what has happened. All references on the X axis are no longer there either? Regards Hayden |
[2020-10-31 14:30:37] |
You need to change to the Sierra Chart Advanced Service Package for the TPO Profile Chart study. Instructions: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
